InToSSH
- Mar 26, 2019
- Czech Republic
Hi,
I am considering buying th A139 Pro as a replacement for my old Mivue J85.
I have read a lot of threads here and found people are reporting a lot of issues so I wanted to ask about the current state with latest firmware and I would also like to ask about some features that are important to me, but couldn't find an answer for:
I hope the A139 Pro has the same features. Geofencing would be nice to have, however the point 4 is a must. My current camera records only 5 seconds prior to pushing the emergency button which is just not enough time and I always miss the event. With A139 Pro if it didn't have the same feature as described in the link I would be afraid that when I hit the button right at the beginning of the clip, I would also miss the beginning of the event.
Or would you recommend any other 2CH DC with similar video quality and features with budget up to $400?
Thank you
- Has the blurry image been fixed?
- Issue with AED parking mode? Or is it still better to just use 5fps timelapse?
- Does the camera turn on and start recording reliably after turning on the ignition (using the hard wire kit)? This was my main issue with my current camera, sometimes it would just stay off.
- How does the manual button emergency recording work? Does it save only the current clip or also the previous/following clip if it is near the beginning/end of current clip?
- Does the camera support geofencing for parking mode? Same as the fw v1.6 for A139 does.
- Some other issues I missed?
Thank you
