Dashcam overheating
peodi3
I am quite disappointed with the operating temperatures with this dashcam. And this should go the same for all dashcams! In places like Phoenix, Arizona where temperatures are high as 115 F / 50C , this dashcam turns off automatically while I'm driving , probably because it's overheating. I have never had this problem before when I had the G1W dashcam, for $80 cheaper! When i buy a dashcam for this much money i expect it to get my money's worth. Especially when a cheaper device performs better than this one. the engineers should have thought of this with heat problems.
Has anyone found a workaround yet?
Turn the air conditioning on? And send the cool air up the glass to the camera.
If the air in the car is 50C and there is sun on the camera heating it further then I would expect it to shut down due to heat, and any camera that doesn't isn't going to have a long life.
What is the air temperature in the car when it happens?
You may be able to improve things by installing a sun shade for the camera so that the sun can't heat the camera directly,
Just about 2 months
ok, the first production run of these had some problem with the temp sensor that wasn't reading correctly, if you've only had it two months it's less likely to be one of the early ones, it may just be some other fault, it's not normal behavior though so you should talk to the seller about getting it replaced
Maybe I just had a bad unit then? I'll try to see if i can get a replacement.
I took mine apart and drilled out every other hole with a 2mm drill but you need to be careful as i broke the screen putting it back together
