If I go into 'Date Time Setting', 'up' increases the value, 'OK' moves to the next value and 'down' decreases the value - How do I get out of that setting?
the same way you enter the menu, press whichever key enters the menu and it will take you out of the menu, if you have GPS though you don't set time and date, only the timezone
I'm not sure if you figured this out, but press and HOLD the UP button; it will beep (assuming BEEP is set to on) to confirm the request. The same method is used to get out from setting the driver plate# as well as exiting the menu altogether.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
