dashingthrusnow
Daylight savings time doesn't work on the HD model... does it work on your SP or 250HD model?
dashingthrusnow said:Looking into this, the setup.bin saves the timezone choice in a hex value from 00 to 5A (literally in order) in offset 03. The question is, how does the program then pull this data to calculate the correct timezone?
Appro_avi_save looks like it has code that loads up the setup.bin file, pulls time from GPS, and then performs some calculations. The system clock is never right (as the 'date' outputs the start of posix time, 1 January 1970).
This sucks, because it's unlikely that I'll be able to fix DST on the Itronics units.
jokiin said:for what it's worth (and I'm not sure if it's something you can fix) the timezone offset detail is carried in the GPS info, we used to do the same, manually configure the timezone but have the time set by GPS, our new firmware now has auto timezone setting now, makes things much easier
dashingthrusnow said:jokiin said:for what it's worth (and I'm not sure if it's something you can fix) the timezone offset detail is carried in the GPS info, we used to do the same, manually configure the timezone but have the time set by GPS, our new firmware now has auto timezone setting now, makes things much easier
That's definitely a better solution. I'm not going to be able to solve this without the source code... Sucks.
Jokiin - what camera do you make and sell?
dashingthrusnow said:Please let me know when you release it!
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
