notyvole
Hi. I have mini5 and HW kit installed. The camera knows that there is that kit installed because the menu is enabled. I can change the turn off voltage. The camera does not see the voltage. Interesting is that when I turn the car off the camera turns off right away. And the opposite when ignition on it turns on. The problem is the 0.0 Voltage reading, that causes the camera turn off right away after ignition off.
Is there some newer English firmware than 7.0.0.21? Or is simply the camera not fully functional?
I wrote to ddpai support but don't expect much help.
Any idea is greatly appreciated.![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
And btw I found on Aliexpress this nice little cheap thing(12V Battery Low Voltage Cut off Automatic Switch On Recovery Protection Module) -- https://de.aliexpress.com/item/1005002483736933.html?spm=a2g0o.productlist.0.0.6d0272282F4hfN&algo_pvid=fd2f0ae0-61c1-4eb8-8f9e-ef7120d8d626&algo_exp_id=fd2f0ae0-61c1-4eb8-8f9e-ef7120d8d626-27&pdp_ext_f={"sku_id"%3A"12000020817667626"%7D&pdp_pi=-1%3B3.01%3B-1%3B-1%40salePrice%3BEUR%3Bsearch-mainSearch
Ordered it and when nothing regular will work I simply wire it and have much cheaper solution doing the same. Should probably done it in the first place.
Just dial off voltage and on voltage and let it be for the rest of the days.![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
