Do I need an anti-discharge device?
Razorblade
Just bought the LK-9390. Reading the manual, it says :
  • Parking mode is active when the device is turned on.
  • Note that recording and the device itself will terminate power if the vehicles' battery drops below a predetermined voltage.
So, do I need one of those parking mode things (LK-290) or not?
It's required if you plan on using parking mode and don't want your car battery going below the voltage required to start the car.
Right. But the camera manual says the camera will automatically shut off below the preset voltage - so do I need the device in addition?
Sorry.. my bad! This one has BDP in-built, yes it will shut off when the preset low voltage is reached.
As long as you're using the supplied hard wire kit, it should work as advertised.
