donnybrook
I can't find anything definitive that tells me if I need more than 1 hardwire kit. Should I be able to power all 3 cameras for parking mode with 1 kit from VIOFO?
You only need one HK4 or HK3-C hardwire kit to power the A229 Pro 3-channel.I can't find anything definitive that tells me if I need more than 1 hardwire kit. Should I be able to power all 3 cameras for parking mode with 1 kit from VIOFO?
Yes one is fine, no place to plug in another oneShould I be able to power all 3 cameras for parking mode with 1 kit from VIOFO?
Thank you! Is one kit preferable over the other?You only need one HK4 or HK3-C hardwire kit to power the A229 Pro 3-channel.
The default hardwire kit sold for the A229 Pro/Plus is the HK4, but the HK3-C will work as well. The only difference between them is the HK4 has a 90° USB-C connector while the HK3-C has a straight USB-C connector.Thank you! Is one kit preferable over the other?
