DCnewb
Here is my basic setup:
Viofo a229 Pro 2CH dash cam, which will connect into a PowerCell 8 battery pack using their spliced HK4 hardwire kit, and the PowerCell 8 will be hardwired onto an accessory fuse in my fuse box so the PowerCell 8 only charges while the car is running. No questions about that setup if that's all I was doing.
QUESTION: I want to add what I believe will be a DPST toggle switch onto the BATT and ACC wires in between the PowerCell 8 and the minimum voltage setting box heading toward the dash cam. No modifications on anything from the PowerCell 8 back to the fuse box. The intent is to be able to cut power to my dash cams - front and back - at any given time using this toggle switch. I don't mind if the PowerCell 8 continues to charge while I'm driving, but I want to have easy control on interrupting the power between the PowerCell 8 and the dash cams using this toggle switch. The ground wire between the PowerCell 8 and the front dash cam will not be altered.
1. Does anyone have experience installing a DPST toggle switch like this to be able to cut power to dash cams?
2. What is the typical wire gauge on the 3 wires in a HK4 hardwire kit?
3. Anything I'm missing missing here in my intended switched setup?
Thanks!
