tekcor
I've been trying to figure out what's going on for a while and I'm running out of ideas. My issue is the parking mode shuts down far too quickly even when the cutoff is at the default 12.0V. I have a new 2023 Pathfinder, which according to what I've read, has an enhanced flooded battery. I'm not sure if the battery type matters for this conversation, so I mention it just in case. I suspected the battery might be bad, so I tested the voltage at the terminals after the car was sitting for about four hours, and I read 11.93V. I let the car run for about a minute, read 14.5V while the car was running, and once I shut down the car it only took about a minute for the voltage to drop to 11.99V before I stopped watching. At no point, even when I read the voltage at 11.93V, did the car feel hard to start.
So I took it to the dealer yesterday, which went exactly as I expected: they tested the battery, starter, and alternator and found no issues. Every test passed. So trying to narrow down the possibilities, I theorized that the ECO mode I keep the car in wasn't charging the battery more than absolutely minimum. I drove home from the dealer with eco mode off - about 15 a minute drive - and tested everything again. 14.6V running, stable 12.4V while off. Great, it must be the ECO mode! The parking mode ran for another 8 hours before it shut down. I did not measure voltage when I noticed the camera was off, I was satisfied with the result.
Until I pull into my garage again this evening and before I can even get out, I hear the "powering down" voice telling me it hit the voltage cutoff. I pulled out my multimeter again and measured 12.2V. Odd that it shut down at that voltage. But regardless, I'm getting pretty frustrated with this.
The camera is hard wired into the accessory connector near the fuse box. For those unfamiliar, many Nissan vehicles use an octopus cable under the dash for electrical accessories, rather than using fuse taps. I've wired the camera exactly like the instructions for Nissan's own rebranded camera: using grey-capped 20-22 AWG positaps, ground to ground, camera ACC to the ignition/white, and camera BATT to the battery/red.
BlackVue customer support says to reinstall firmware, so that's just their way of saying they have no idea. I'm thinking there is some sort of incompatibility between this car's electrical and the camera. Nissan's rebranded camera also does parking mode, and also has a voltage shutoff, but I don't know what the threshold is. I haven't been able to find that figure. I think it's a Thinkware camera. So given that they have their own dual camera system, I feel like this should work without issue. I just don't know what else to test. Nor do I have any idea why the camera ran for 8 hours yesterday. I'm guessing something that the dealer did during testing got some extra juice in the battery that normal driving isn't getting. I've had this issue even after hour long drives, which leads me back to the battery either not holding a charge, or the alternator not fully charging it.
Please, give me some sort of idea.
