Today I received the camera and was happy with it until the **** good ****.The mini camera is an E-Prance 0805 one A7 with 8GB internal memory.Tell them the problem be if someone can help meBut I take very clear and expensive.I think I loaded my camera.Try updating the firmware and I think I did it wrong.And the ****.Them will say all the steps I took to have no doubt.And I did not backup.Install in the internal memory and external to update both.Turn the camera off and on again told me that if I wanted to install it and said yes, and even there thinking it was going to be OK.This was done and after installing all made a funny noise that came from the speaker, I will not describe it.Since then I have not been able to return it has turn zilch screen all black, all it does is take the power light blue you think it means to stand by and just get shut is giving the power button and one of the up or down for about 18 seconds.If you load and when I connect it to your computer or stream 12v. recognizes neither the camera nor the sd card to the computer.When I connect the camera to the computer the light turns me like purple.And since I am unable to make it work.Does not recognize the 805 or micro sdHave someone knows how to arregralo am very desperate and do not get anything.Would greatly appreciate it if someone could help me on how to remove the release you have.Greetings.Enrique.
