E1 Pro question
Predat0r
Newfoundland
Viofo A329, Vantrue E1 Pro
I have an E1 Pro for testing and I have a question about camera operation with the camera hardwired. I have been testing the camera with the OBD cable and I understand now how parking mode works. However, if parking mode is turned off, the camera doesn’t shut down as I thought it might when the vehicle is turned off. It has constant power all the time. My question is, does it operate the same way when hardwired to the fuse panel? If not using parking mode, does one need to manually shut the camera off each time the vehicle is shut off?
If the E1 Pro is powered by the Vantrue 3-wire parking kit and the parking mode is disabled in the menu, then when the ignition is turned off, the E1 Pro will turn off.
As far as I estimate (please correct me if I'm wrong) you need to shut down the dashcam manually when using the obd-hardwirekit.
It's more likely a power-cable with battery-protection and switches from regular record to parking mode when detecting no motion for 5min
The ACC-Hardwirekits from Vantrue will work like karagandinez described it.
If you use the hardwire kit to hardwire the dash cam to fusebox
1. Connect the ACC wire to a power source that is only powered when the ignition is on and has no power when the ignition is off. Connect the black wire to the negative terminal (ground).
When the engine is turned off (Parking Mode ON) – The dash cam will quickly enter Parking Mode.
When the engine is turned off (Parking Mode OFF) – The dash cam will shut down immediately and will not drain the car battery.
