kamkar
- Oct 11, 2013
- Denmark
- 10 years, many dashcams
So i got this camera from Vantrue to test.
I put it in yesterday, and i can see i put the front camera a tiny bit too close to another camera, but it will work for now.
The rear camera when installing it i was surprised by a sudden strong shower, so that is my excuse for it being mounted a few degrees off axis.
So far just been touching and feeling, and absolutely nothing to be sad about here.
So today i got a little daytime footage in, and i have "run" into some "issues"
First of all driving on a slightly uneven street in town ( past the horse statue )
www.google.com
I think the front camera vibrate a little on its mount, at least it look so when looking at the bottom of the picture where you can see the bottom of the windscreen and the air vent ( more footage on this later on )
Then out on a near by rural highway i wanted to do some plate capture, and sure the camera also do that just fine, but it could be better it seem.
The reason is blocking in the footage, which depending on how you look at it change a little, if i use pot player then every 15 frame are perfect, the other ones have some degree of blocking ( blocking are not uncommon )
Compiling a video to display this using power director 17, there was however a change in the good frame spacing, and now using that software the spacing are uneven.
So i wanted to take 30 frames and space them out sort of like stop motion cartoon, but i missed some so i just have 28 frames.
So my video start on a good frame ( i made the good frames larger than the bad / blocky ones ) and i also numbered every frame in the top R corner.
But here the first frame are good, then the 10 frame and then the 23 frame, so that is a bit strange, using pot player if i start on a good frame then frames 0 - 15 and 30 are good, every 15 frame.
I am pretty sure i have used the best birtrate, which for this raw file are 14399kbps, so it is H.265 encode i assume.
If you want to have it even slower you can use slow motion on youtube, but i feel the "bad" frames are easy to spot focusing on the road directly in front of my car.
I noticed this wanting to compile a plate capture video, cuz doing that i go frame by frame, and then you can easy see when a car plate are in the sweet spot ( readable distance ) on a good frame VS one of the pixelated ones.
I do wonder why it behave like this kicking up super nice frames now and then, but then the in between ones are a bit blocky.
I will have to pull a memory card from another camera to compare, but i think i would have noticed this too with other cameras, i think those are just blocky to the degree the amount of detail at the scene prompt, but do not cough up extra crisp frames like the E2 do.
As i understand these was just changed to do H.265 compression, so not sure if this is something that have occurred in that change from H.264
Once again dashcam footage being a bit blocky now and then are completely normal, some times the bitrate get overwhelmed, and thats just how it is.
Where this is recorded there are some trees lining the road but not unusual in my plate capture videos for various cameras i have tested.
Google Maps
Find local businesses, view maps and get driving directions in Google Maps.
