It indicates it was a slow speed card if voice prompts "sd card low speed";
One MByte missing from the card, so that is why you should format the card in the APP or power the dashcam once again. It might have some unreadable files in your memory card!
Although I think you already know it and for some reason you have forgotten it or are deliberately ignoring it, depending on the size that is assigned to each writing block at the time of formatting, more or less wasted space may remain without formatting and therefore That space is inaccessible. That does not mean that there are illegible files or have damaged parts. If my SD is formatted from the APP or with the guiformat2 utility, all the available SD space is left, nothing is wasted and that is what the second test indicates. If the SD is formatted with SD Card Fomatter, 1 MB is wasted, which is what the third test indicates. If I used the third time "SD Card Fomatter" has been to follow the instructions of SawMaster in the thread that recommended me to follow.
Assuming the message is "Low-speed sd card" only means that, but it does not necessarily indicate that it is the fault of the card. Perhaps the card is fine and whoever has the problem of slow writing or verifying the writing is the camera itself.
It is clear that you are determined to blame the card for the problem, but have you read the part where I commented that I can record continuous video without errors at 3840 x 2160 (4K UHD) 30p from my camera? Don't you think that requires much more speed than what the B1W needs? Why with the camera I have no errors?
Look, the SD is in warranty period and I would have no problem changing it, but it only fails with the B1W so a coherent explanation of that fault would be necessary or you should recognize that my B1W does not handle writing well in warm conditions.
Thank you
Aunque creo que usted ya lo sabe y por algún motivo lo ha olvidado o lo está obviando deliberadamente, dependiendo del tamaño que se asigna a cada bloque de escritura en el momento de formatear, puede quedar más o menos espacio desperdiciado sin formatear y por lo tanto ese espacio queda inaccesible. Eso no quiere decir que queden ficheros ilegibles ni que tenga partes estropeadas. Si mi SD se formatea desde la APP o con la utilidad guiformat2 queda todo el espacio de la SD disponible, no se desperdicia nada y eso es lo que indica la segunda prueba. Si la SD se formatea con SD Card Fomatter se desperdicia 1 MB que es lo que indica la tercera prueba. Si utilicé en la tercera ocasión "SD Card Fomatter" ha sido por seguir las indicaciones de SawMaster en el hilo que me recomendó seguir.
Suponiendo que el mensaje sea "Low-speed sd card" solo significa eso, pero no indica necesariamente que sea por culpa de la tarjeta. Quizás la tarjeta esté bien y quien tenga el problema de la lentitud al escribir o al verificar la escritura sea la propia cámara.
Está claro que ustedes están empeñados en culpar a la tarjeta del problema pero ¿ha leído la parte en la que le comentaba que puedo grabar vídeo continuo sin errores a 3840 x 2160 (4K UHD) 30p desde mi cámara de fotos? ¿No le parece que eso requiere mucha más velocidad que la que necesita la B1W? ¿Porqué con la cámara de fotos no tengo errores?
Mire, la SD se encuentra en período de garantía y no tendría ningún problema en cambiarla, pero solo falla con la B1W por lo que sería necesaria una explicación coherente de ese fallo o deberían reconocer que mi B1W no gestiona bien la escritura en condiciones cálidas.
Gracias
