adorfer
- Apr 30, 2013
- Germany
As a rear view camera i replaced an older model with a this module from AliExpress for about 50€.
It's a Sony Effio-P board with "extreme WDR" and tons of configuration options.. so you can tweak it's settings, especially for low light and high contrast treatment to the maximum.. so if you prefer more grain or prefer decent black areas if it's dark. Where you want your clipping masking and what about number plate readability. I just put it in a good cast metal case. The image is flipped (due to more convenient placement of the cable exit) and mirrored (not to get confused when looking alternativly at the "mechanical retrovisors"). Off course it's only PAL resolution, but for a rear camera that's enough at least for me.
Since i do not fear grainy image, i put the gain up quite heavily. So here a sample of nighttime drive: industrial area, retail area, overland road, fastfood drive through, residential area.
it's filmed through the rear window. compared to the original optics, i did change the lens for a f=8mm F=1,4. the rear window is a tanned glas of about 80% reduction. so the match "better lens" against "heavy sun protection glas" is probably 1:1.
And yes, none of my other camers does match THIS low light capabilites, not the PowerUCC Panorama2, nor the Pixim Seawolf.
You will see how much the scenery get's illuminated when i hit the brakes and consequently the breaking lights fire up. (and no, there is no "action" in the total video. So do not expect anything to happen.)
And no, the camera is not out of focus, it's the multi exposure ("3D noise reduction") which blurs the image.
