F770 features
tabetha
My F770(front+rear) cams are hardwired, the parking option allows for up to 48hrs surely this can't be right ?, if NO is selected instead of record time owing to it being hardwired would it stay recording in parking mode all the time ?
When playing back footage from the SD card from the cam should there be a map displayed in top right corner ?
From what I understand if just hard wired it will continue recording untill it reaches the cut off point voltage that has been set in the settings, the default is 12.2volts.
Thanks, I have set my cut off to the lowest point, fortunately and with it being auto I always ram in the biggest battery that I can so it's 80ah, it is just confusing this 48hr option, there must be many cars parked longer than this, I carry a lithium jump pack with me in car anyway, though car has started at 10.4 v with original battery(just).
If I get a chance I will test to see if it stops at 48hrs or at voltage by leaving a battery saver plugged in, if it stops it is obviously timed I have a sierra cossie that I am putting a F770 in and that is left on battery saver, having alarm/immoby/tracker then dash cam to power battery goes flat in no time!!
Thanks for info,
regards chris
It will certainly stop @ 48hrs that is the max allowed. As Jokiin says storage would run out anyway as for a 2 camera set up in Time Lapse with Partition set to C the most recording you can get is 41hrs.
I get the bit about 48hrs stopping recording, just cannot understand why, if for example car was parked for three days why shouldn't I be able to record for this length of time, say something happened 3 hours before I got back to car, on the loop recording thingy it would still have the footage, yes it would be bad luck if something happened say 30 mins after I left car as this would be written over, but that's sods law, just wish it would continuously record so long as it has suffecient power, so it could be in car cctv, for cars not often used but kept on trickle type chargers.
What is partition c please ?
I'm still waiting on them to allow custom partitioning like other camera
Jokiin, thanks for that after I posted this I saw that on a video on the guys phone, it would help if I had a up to date phone, mine is so old it doesn't even go on the internet!!
Regards chris
