Chromatic
- May 18, 2014
** TLDR below**
I have two of the Version 2 Mobius "Actioncams".
One I use for my dashcam,.. and the other is more mobil , but usually in car aimed at some electronics for another "hobby" if you will.
Now.. I've been ordering batteries thinking one or both of the mobius's have been having batteries die every few months.
However,.. I figured it out.. (duh).
My Dash cam mobius (I have them marked) -- had a LITTLE bit of water spilled on it , on my desk when I was getting footage. I immediately dried it proper.. and it worked fine.
but that must have caused this issue..
Anyhow.. here's the deal.
The dashcam mobius,.. it kept losing it's date/time -- and I know that's the battery dieing.. however I have these hard wired so they get power the whole time they are on and don't need to use the battery.. and are being charged as well. So there is no reason the battery/time should be gone.
Well I replcaed the battery in both cams.. and of course that made it work for a few days.. and then same problem again.
Anyhow.. Now I can take the Second mobius (non dash cam) and put the dashcam battery in it .. hook it to my PC, or the wall, etc.. let it charge for an hour .. Put it back in the casing of the Dashcam.. and it's fine. (works/date stays / time stays).
*** Start reading here if TLDR **
So given that one of the mobius's just doesn't charge the battery but otherwise works/records fine,.. Is there anything I can do short of replacing the whole PCB for $50+ ?
IE: Can I fix it? I work with PCB, computers, electronics, batteries, etc a lot.. am handy with a soldering iron -- I just don't know what to look for, or if anything could be done, or how to determine where the problem is, etc.
I've priced a new PCB and it's close to the price of a new mobius.. so this is why I want to salvage this and make it charge again.
I'd send it to one of you and pay you some sort of fee if you could fix it..
Otherwise, any links, tips, pics, etc on how to perhaps, repair it?
Thank you!
Chromatic
Thank you!
Chromatic
