Wouldn't have thought it possible in a petrol engined vehicle.I had a really good run in my 1977 VW camper van. Really impressed my passengers after driving through 4 feet of water.
depends on how well your intake (and doors) are sealed up, and how long your snorkel is.Wouldn't have thought it possible in a petrol engined vehicle.
Too big job for his windscreen wipersOk, this is not an actual dash cam video but surprised me.
i think the old VW microbus engine air intake was at the same level as the windows, on the rear corners. so it sort of had a built-in snorkel system. and as long as you stay on the throttle, no engine will suck water in through the exhaust.
The bugs were a bit more weatherproof
I did manage to get a full sized pickup stuck in the sand at a place I worked at as a teenager, and was embarrassed when an old guy pulled me out with a VW 'Crew cab' type bus, and a fairly old one. Not sure the HP of that year, but would bet it was 50-60 HP.
I once owned a '64 VW with 40HP (upgraded from 36 HP in previous generations). And I can also confirm they will float having 'accidentally' driving mine into the Atlantic Ocean off the coast of Virginia.50-60 HP! The phrase 'Couldn't pull the skin off a rice pudding' comes to mind.![]()
Yes but how far did you get before the engine coughed and diedI once owned a '64 VW with 40HP (upgraded from 36 HP in previous generations). And I can also confirm they will float having 'accidentally' driving mine into the Atlantic Ocean off the coast of Virginia.![]()
There used to be a story about the VW Beetles being so well sealed that you had to open a window before closing the doors.
