firmware 202
unpaidbill
St. Peters, MO
I'm running the 202 firmware in cam with GPS and internal memory. When I play it back, it's showing KPH instead of MPH. Do I have some setting wrong?
some version have an option to select, most are fixed one way or the other, need to try another firmware if you have no menu option to change it
You could use 20131202 which is MPH-only or anything above (Switch between mph/kph)
