Hey Lenny,
Cannot do that, all voice alerts work as a whole sound bin file, cannot set up in firmware one by one!
Just a quick comment, I think there is still a bit of confusion, and perhaps
@Blockisle9's request could be described differently.
Right now, the B1W plays two sounds at startup, one indicating that the SD card was found, and another indicating that the camera has started recording. Both of these are sounds indicating that a condition or situation has succeeded.
What
@Blockisle9 was suggesting, was that instead of indicating SUCCESS, the camera could instead play sounds in response to ERRORS only.
So for example, in a normal case, if the card was found and the camera started recording, the camera would remain silent.
However, if the card was NOT found, or the recording for some reason could NOT start, that is when the camera would play a sound - "SD Card Not Found!" or "Camera Cannot Record!"... something to that effect.
So it's not a request to change the sounds to beeps, or to selectively disable certain sounds from playing... it's a request for an alternate set of logic or conditions for when sounds should be played.
The end result would be a camera that was generally quiet, only making sounds when it had a condition requiring attention. It's sort of like how your car's dashboard has a "check engine" light that only comes on when something is wrong - as opposed to a "Your engine is OK!" light that lights up every time you start it.
(And a note for @Blockisle9 - If you enabled this, you would have to be absolutely sure your method of powering the camera was reliable. Otherwise a camera with a failed power source would seem the same as a camera that had started successfully - i.e., there wouldn't be any power to play any warning sounds.)
