During the day is a little better, night time video without CPL filter almost the same ( maybe only for me,didnt notice too much difference ). I noticed tonight that battery in my Yi is at the end of a life time, and Yi is turning off during the start up of car's engine because there is some short cut off power and then power comes to Yi ( that short pause in power supply causing dashcam turning OFF an ON few times in a row ). I dont know what is problem exactly but I suspect it is something with image sensor. I even tried different sd card which is running in WR 1 but its same thing,no success to improve the grainy,out of sharpness and bright light annoying effect. Dont have a clue what to try to do next except maybe dismantle-take apart YI again and try to adjust lens in night time condition toward the street lights to see if then will be some improvement in video look.doesn't look great
how does it look during the day?
how is the night video without the CPL?
Any cure or idea whats the problem with? Any solution execpt I trew it away in garbage?yeah doesn't look very good, looks like 720p interpolated to 1080p in those videos
I didnt noticed anything on a lens, there was a glue on the side of the lens, but I dint melt it down, I scraped it off and didnt put any glue instead of old one, I just screw the lens in thread (dont know english words for that,but its like a cap on bottle, screw it one way and bottle is open,screw it other way,bottle is openI don't think you've done anything wrong yourself, if you're pulling it apart again maybe make sure the lens is clean on the inside, have seen issues on some cameras where the glue used in lenses ends up fogging up over time and leaving a film of gunk inside the lens, has a similar result to what you're seeing when that happens
