Fogged Up Windscreen
TonyM
Many dashcams over many years
I have the same problem every Autumn when the temperature drops a bit. My windscreen can be clear on the inside when I get in the car, but shortly after starting the engine it fogs up and takes ages to clear.
This morning was a typical example. It took 6 minutes from turning the engine on to be able to drive away. The outside temp was 3degC.
When the car starts the AUTO A/C setting sends air to the windscreen and footwell. When I noticed it fogging up, I set it to Defrost which sends a full A/C blast to the windscreen only. On icy mornings it can sometimes take 10 minutes to clear.
I don't like to wipe the windscreen when it's wet as I've read it only makes things worse in the long run. But some days when taking the kids to school, I don't have the time (or patience) to wait for the window to clear without resorting to rubbing it with a microfibre cloth.
I leave the air vents open overnight. I have one of these dehumidifier bags in my car which seems to work - to a point - as the screen was clear when I got in the car.
This is the third autumn since I bought this car (Mazda 6 Estate) and I get the same thing every year, worse than with previous cars. I've had the air and pollen filters replaced with no improvement.
Sometimes I deliberately keep the A/C off first thing in the morning, or intentionally direct the air away from the screen, but that doesn't really work.
I suspect there's ponding water or something damp in the airflow that's sending damp air into the car, but I don't know where to look. I've not found any evidence of leaks or wet footwell carpets for example.
I'll give the windscreen interior a good de-greasing clean tonight to see if that helps.
Any suggestions on what to do?
I have wind/rain deflectors on my front windows so I can leave the windows open a good couple of inches when i leave the car overnight. this also helps by creating a cross breeze so deflecting any warm air rising to condense on the inside of the screen. As soon as I get in, I close all my windows tight & shut the vents so the only air is recirculated air. I then set my aircon to max & it clears in no time.
Aircon tends to dry out the air, so any dampness is quickly dealt with in the aircon unit where the dampness is condensed & can run out of the car.
...had a similar issue with my trusty car; until last spring, when i found out i had a little rust-problem; after welding it shut, everything is a-ok again...
...do you "smell" some exhaust-gases while driving? if yes - check the bottom-part of your car...
(and put the de-humidifier on a heatsink now and then, you won't believe how much water they pull out of the air)
Do you have a control to select whether air comes from outside or circulates inside?
Outside air may be cold until the car warms up, but it clears the screen a lot better. In fact blowing air from inside around just seems to make things worse for me.
If you want cheap silica gel, buy a huge bag of pearl/crystal cat litter. I keep meaning to make up some cloth bags for this.
Yes, I have a recirculation control. I'll watch the de-fog mode to see what it does, as I might be better off overriding it manually.
I've read that I should clear the air intake under the windscreen, where the fallen leaves tend to collect. If that is blocked, or full of wet decaying leaves, I can see how that would affect the air coming into the car.
apropos cleaning air-intake:
also replace the driver-cell-particle-filter of your AC (if built in) (don't know how to translate it: the part cleaning the air from the ac that comes inside the cabin)
...if that's saturated, it can be the cause, too
pollen filter?
Outside air may be cold until the car warms up, but it clears the screen a lot better. In fact blowing air from inside around just seems to make things worse for me..
That's due to all the moisture in your breath. That's why I crank up the A/C and close off the vents because of the way it dries out the air, don't want to introduce any more moisture than is necessary.
I could try closing the vents and running the A/C as you suggest, as the outside air is actually rather damp, possibly more so than the air in the car as I don't have condensation on the inside when I get in.
The vent system on my car really is crap. Only choice with windscreen is to have all air directed to screen or split with screen/feet. when I try the latter, screen still fogs up so I always have to have screen only & always need aircon until the air blows warm.
In the cold weather, I rarely have the luxury of warm hands for the first 15 or so mins of my commute
