ShadowBroker
- Nov 29, 2016
- Canada
EDIT: SOLVED
"After returning the faulty G.Skill micro SD 128GB card, and buying two new G.Skill 128GB cards for my A119s, both new G.Skill 128GB cards have been working FLAWLESSLY for three days now, recording over 30 hours of video footage. This clearly indicates that the first G.Skill micro SD card I used was defective from day one."
ORIGINAL POST:
Joined this forum only for the purpose of reporting my experience using a G.Skill 128gb mircoSD card with two VIOFO A119 units with firmware version 2.0. One is powered through a hardwired kit connected to a add-a-fuse kit, while the other is powered via the supplied USB lighter-plug adapter provided by VIOFO. Both are equipped with, and powered through the GPS module USB port.
The issue I consistently experience is that upon restarting my car, there is a memory card error. Attempting to reformat the mircoSD card through the A119 menu fails every time, and the A119 continues to display that there is a memory card error. Only reformatting the card on a PC actually reformats it, and it can only be reformatted to exFAT, not FAT32 as required in the A1119 manual.
Upon reinserting the card into the A119, and powering it on for the first time since reformatting it on PC, the A119 prompts to reformat it. The A119 then reformats the card successfully. I can then drive for as long as I want issue free. However, as soon as I power off the A119 for 5-10 minutes, then power it back on, the A119 displays the same memory card error, every time.
Having two of these cameras, I have tried combinations of mixing the GPS modules with the two A119 units, and mixing the methods of supplying power between the hard wire kit and provided lighter-plug adapter. Consistently, the G.Skill 128GB card fails upon restarting my car, no matter in what configuration, and needs to be reformatted via PC.
Interestingly, an old 8GB Class 6 card of mine has no issues at all in either camera unit, in combination with either GPS module, and with either power supply connected. Given that at least one other forum user reported the same issue with their 64GB G.Skill mircoSD card, I think it would be wise for A119 owners to buy another brand of mircoSD card. I have a Samsung Evo 128GB microSD card that I use with my mobile phone, and will report back it I experience any issues with it in my A119 units.
ORIGINAL POST:
