I've had my G1W for 2 weeks and its worked great so far. When unplugged, it runs on battery and shows the battery indicator; when plugged in the indicator shows it's charging. The auto-record when plugged in to the car adapter worked great and it shut off within seconds after the car was turned off.
Now, all of a sudden, it thinks it's charging all the time whether it's plugged in or not and the automatic stop recording and 'Goodbye' after a few seconds doesn't work. No matter what, the indicator thinks it's being charged - which means every time I turn it on, it starts recording. I've let the battery run down to see if it would reset and I've also used the reset button - still the same problem. Now I have to manually stop recording after each time I drive the car and when I turn it on at home, I have to stop the auto-record and then delete the useless clip it creates each time.
Is there any way to get this back the way it was?
