Garmin parking mode cable, how does it work?
wkqas
Barnsley
Has anyone reverse engineered the Garmin parking mode cable to figure out how it signals the dash cam into parking mode?
USB Pin 1 is +5V, Pin 5 GND and Pin 4 signal parking/continuous mode.
Something like this?
Pin 1. +5V
Pin 2. NC
Pin 3. NC
Pin 4. +5V continous / 0V parking
Pin 5. GND
I am not sure about the ID pin. I measured 2.8 - 1.8V depending on park/cont. mode. I don't have an oscilloscope to see if it is just a simple voltage rise/drop.
Two resistors are used to signal park/cont mode.
With ACC on, ID pin resistance to ground is 12.9 kohm.
ACC off its 30.9 kohm.
The dash cam has a pull up on the ID pin. When the parking mode timer is up the dash cam releases the ID pin, it drops to 0 v and the switch mode converter is shut off. It can't power on again until you turn the car key. Some speculation there.
