Git3 review
Tungsten E2
Germany
I only have the Git3 for a couple of days, but I have mixed feelings about it.
Here comes a list of some findings:
- no change of setings possible when cam is in case due to touch screen. that was better with the Git2
- in menu of Git2 you saw the settings of a menu item directly, in menu of Git3 you have to open the menu item first to see the actual setting
- the red LED on the back is very dark
- LED blick frequency is very slow, rised feature request on that
- FOV is smaller compared to Git2, GIT3 is missing FOV menu setting for this
- got some strange purple colors on my first timelapse video outdoor. need to check if this was due to sun position
- sometimes the touch screen does not work correct when pressing the low corner symbols
- case layout changed a lot. dimensions of the front lens ar totally different to Git2. External diving filter equipment does no longer fit.
- main advantage of the Git2 was that GoPro accessories could be used, this is no longer the case
You should use the Zoom setting, another name for FOV...
Most GoPro Hero 4 accessories can be used, certainly the mounts, microphones and lens filter mount for when not in the case.
It is more compatible with Hero 4 accessories than the newer GoPros are!
thx, so do the Hero 4 cases fit the Git3?
Probably not, the Git2 fits a standard Hero4 case and will fit a G3 case, but only with a spacer because the G3 is thicker. Possibly some of the Hero 4 cases are designed for use with the Hero 4 screen and might fit?
Probably best to use a G3 case, and while some GoPro accessories designed for the Hero 4 case may not fit, others will or there may be other options...
