GPS Mount Compatibility
DaveTheJoker
Can I use the Mini 805 GPS mount with the Mini 806? That would allow me not to have to buy the GPS version of the 806.
Thanks.
What about the mini 0803 mount? I hardwired mine and don't really want to have to go through all that again
They are not quite the same, at some angles the wide angle lens of the mini 0806 can see the 0801/3/5 mounts in the top corner/left edge of the image, the 0806 mount has a lower profile so does not get in the image. Probably not a big issue though unless you want to use it mounted upside down.
Using 21:9 cinema mode will probably also remove the mount from the image if it does appear in the top corner.
I should have clarified, question was 0805 mount, then how about 0803 mount, in which case 0803 mount will work just like the 0805 mount would, neither are the same as 0806 mount in profile in case that's not clear
