GPS wrong location
xBladeDragonx
Anyone else have issues where the GPS cannot pick up where you are? The GPS matches my speed, the marked road, and the tracker follows the movement based on my turn by turn driving, but for some reason, the map overlay of the GPS puts me somewhere in China. How do I allow the dashcam to sync up the GPS so the location is correct?
Your dashcam and GPS base is defective send it back.
just kidding. Anyways you're using the software that came with the camera on the SD card right? The program they bundled on that firmware is acting weird. Try using Registration Viewer or using the CD with the software. That should tell you you're in the states.
Thank you!! This worked!! I was just about to return it to Amazon thinking maybe it was defective....
My issue is slightly different. The gps logs the correct positions but the displayed positions are wrong. It turns out that the map is displaying east longitude instead of west. This means that map shows me in Belgium instead of the UK. Also the turns are reversed. The track therefore is a mirror image of the actual track. I think the problem is the longitude sign (+) is incorrect when passed to google maps. Does anyone have solution?
What are you using to view? If you use registrator viewer there's an option to flip the output which would probably correct that
