Sabe
- Oct 6, 2012
- Finland
- G90, GT300W, Mobius A, C
Test report using varifocal lens on GS5000.
I used cheap lens first because i had no idea what it does, and this is dx item sku 45186, very cheap and quality is not good i think.
Why i did this? Just for fun, and so that you don't need to do it.
What i have found is that lens is very heavy and my lens mount broke, but add some glue and then you are back in business.
I had to widen the front opening with a grinder to get lens fit properly, and it would be good idea to attach lens to outer cover with glue.
What is good in this type of lens is that outer ring where you can set focus to desirable distance without disturbing basic lens setting.
What is really good is better night view because this kind of lenses have better F rating. Basic lens have aperture size like F 2.0 and this varifocal have F 1.6 so it is better in the dark. This number goes backwards, smaller the reading, bigger the hole.
This lens has range of 3.5 to 8 mm, but i have to say that this lens can't really go to traditional 3.5, so the angle of view is not so wide.
You can see from test image that it really improves night sight, there is two samples side by side, one is taken with original lens GS1000 and other one is GS5000 with this lens, and there is very clear difference at night view.
If you are very in to this idea, you should buy better lens with better ratings, like this one which starts from 2.8 mm.
http://peauproductions.com/store/index.php?main_page=product_info&cPath=26_4&products_id=59
I don't have any daytime samples yet, it is still possible that too much light can burn sunny image to useless.
[thumbnail]https://lh5.googleusercontent.com/-gO5GLXVai6M/UNTI0gg552I/AAAAAAAAAPQ/hyTZntl9Z6M/s696/Dsc03778.jpg[/thumbnail]
[thumbnail]https://lh4.googleusercontent.com/-z5ga1u6ULQY/UNTI1RQRSVI/AAAAAAAAAPQ/o6eIIPpFGdA/s906/Dsc03793.jpg[/thumbnail]
[thumbnail]https://lh4.googleusercontent.com/-o7k2gytUtKY/UNTI0hzvmMI/AAAAAAAAAPQ/8nvCahgIBfw/s1063/Dsc03784.jpg[/thumbnail]
[thumbnail]https://lh3.googleusercontent.com/-pygO4QGRX8w/UNTI1nf_ucI/AAAAAAAAAPQ/X09vJZgrUXA/s696/Image1.jpg[/thumbnail]
