What brand memory card?I've had it over a week. When I insert a memory card the menu functions become inaccessible, and the camera won't record. If I pull the memory card, it works fine, menus are accessible again, any help?
Maybe try and make a note of the process while it is in english.the memory card is a no name and has worked fine for a weeks of so. I've also heard that a hard reset will change the language, so i'm not sure if i want to do that.
I have never had a problem with my Loop not being set up, but maybe I did set it when I bought the camera and forgot. I don't know why that would completely lock you out of the menu though, but hopefully you can get it to work.I have a feeling the card is full and it didn't start back at the beginning to record new files, I can't check the card my reader isn't working. I'll have to check it tomorrow.
I have never had a problem with any card, SD, microSD, brand, size, class or otherwise. Glitches have always been with the cameras themselves and generally speaking, a hard reset or re-installation or update of firmware has been the fix-it..
It is interesting that two G1W-C owners are reporting the same problem. It is hard to say what the cause of the issue may be at this point but it is also interesting that both state that they are using "no-name" microSD cards. Somebody needs to try a quality name brand card to eliminate this question.
Sometimes they can be OK but very often cheap "no-name" memory cards are NOT a bargain! They can even damage a device. In certain high end cameras such as Nikon DSLRs the company specifies specific brands of memory cards that are authorized to work with their cameras and if the camera should fail while you are using another brand or a no-name card they will not honor the warranty.
Then again, it would be interesting to know if this problem is exclusive to the super-capacitor version of this camera.
which sounds pretty similar to our first problem, maybe also sd card related.Not Recording / Responding
One owner has reported that the G1W started to turn off without showing any signs of turning off (the red light was on). When trying to press the buttons they would not respond with the exception of holding the ON button to turn the camera off. The video files were corrupted as well. There is no known solution and the camera appears to be defective.
To everyone having issues with noname cards. Make sure the card in question can actually store the advertised capacity. Copy 32 Gb of any data (or whatever capacity the card is supposed to have) to the card using a card reader (not dashcam) and then copy it from the card somewhere. See if you get any errors and watch the speed of copying.
Cheap cards can very well be 4 Gb in reality but marked as 32 Gb or such. And/or be class 2 but marked as class 10.
