mgfvvc
I'm thinking of having an A229 fitted. There seem to be 2 options for hard wiring, a fuse tap and an HK4 kit. There is no clear explanation of which parts are required.
Reading between the lines I think the fuse tap is the minimum requirement, but with just a fuse tap you don't get parking mode.
Although the HK4 is described as a hard wiring kit it does not contain all the parts required to hard wire the dash cam and a fuse tap must also be bought.
Is that correct? Am I missing anything?
