Hi everyone.
I am currently trying to hard-wire my DVR-207GS. However, I just can't figure out how to get power to it. Here's my setup:
The idea is to use an add-a-circuit (this one specifically) to add an extra 12v accessory lighter power outlet (I am using this one). Then I will plug the DVR into the new cigarette outlet.
Here is what I have done so far:
1. Opened fuse box. Look for spare 15A fuse. Take the fuse out of the fusebox.
2. Plug new 15A fuse into Add-A-Circuit.
3. Plug Add-A-Circuit fuse into fusebox (where the spare fuse used to be in step 1).
4. Cut off end of add-a-circuit, solder this wire to the RED WIRE on the 12v cigarette power outlet.
5. Wrap BLACK WIRE of the 12v cigarette power outlet around ground screw near fusebox. Screw it down.
6. Turn on car (everything is powered when the car is powered).
When I try to plug anything into the new cigarette power outlet, I get no power. Am I missing a huge step here? Should I have more than one fuse in the add-a-fuse?Here is a picture of the setup:
