I am not absolutely sure of this answer, but I believe that it is only a sensing connection. I say this because if you provide 12V to both the Battery and the Accessory wires, and then remove the 12V from the Battery wire, the camera will turn off.
Hence it is not being powered by the Accessory wire.
If/when I get a chance, I'll put an ammeter on the Accessory wire and measure the current draw.
RodeoGeorge
