Hardwire kit stops working
Mick A
I've installed a second hard wire kit and still have the same issue and that is the power supply stops, to the dashcan, after about 5 minutes. After checking with a multi metre i can confirm that there is power up to the black box but, and I'm unable to check, there appears to be no power from the box to the dashcam.
Can anyone shed some light on this please?
Does the hardwire kit have a low voltage cut off to prevent your car battery from discharging? I looked, but couldn't find out. If so, is the car battery voltage above this cut off voltage when the cam stops recording?
You could also try phoning NB customer support on 02920 866 429
If you've installed a second kit then my pointer would be to rewire it to another power source.
Maybe your chosen circuit goes dead under certain circumstances.
