StinkyCheese
Is there a way to have constant power AND have the camera turn on (if off) with ignition? I've got my 119S hardwired with the battery wire on an always hot fuse and I put the ACC on something that comes on with the key (somewhat). I would like to rig the camera to turn on automatically when the truck is started. Is that ACC wire only for changing from parking to regular mode? Before I spend all the time running the wiring to the fuse box under my hood to an actual ignition fuse I thought I'd ask on here to see if that's even possible. Just to provide more information I've got the ACC tapped into the fuse for my steering wheel back lights. So while not true ignition the button lights only come on when I have the running lights on or when headlights are on. Since I always push the button to turn my running/driving lights on I thought that would have been a good place to tap into. I'm sure I can get my buddy to setup a relay or some sorts but I would like to do it the easy way if possible first.
