peteski2019
Hi
I'm hardwiring into a new car as we speak and having had the camera work perfectly for a couple of years now in a different car using the same set up I'm lost.
Set up is the standard affair of;
Supercap in Mobius 2 into 24-12v to 5v with ground and fuses all ok. Have 'visually' rechecked the grounding point as well and it seems ok.
Camera should and has in the old car fired up with ignition,, flashed consistently yellow to show active recording then shut down on power loss and saved down the recording perfectly.
Camera works fine usb into cigar lighter so camera is definitely not the issue. Weirdly yesterday the camera did briefly work fine recording as soon as ignition came on and shut down as it should. Whatever the fault is it seems to be intermittent. Although today it isn't working at all other than to flash as per the below sequence.
The camera on startup flashes as follows Blue-Yellow-Yellow-Yellow-Blue and off no more lights nothing. No idea what the led light combination suggests and can't find anything in the manual at all. Very frustrating as last time this was a breeze to do.
Any suggestions would be greatly appreciated.
