petesamprs
- Jan 16, 2016
- Afghanistan
I have a Mobius v3 with supercapacitor. It is hardwired to my car using an add-a-fuse, and then this 12v-->5v adapter from ebay: https://www.ebay.com/itm/221886479893
The fuse it is attached to powers on with the ignition, and turns off when the car turns off. The same fuse also powers my hardwired radar detector (valentine 1).
My car is a 2014 BMW 535i. It has the engine auto start/stop "feature", but I've turned it off so the engine is always running.
Here is my problem: about 10-20% of the time, after a few minutes of driving I'll notice that the Mobius isn't on and i'll need to manually turn it on. I'm not sure if it either never fully turned on initially, or powered off sometime while I was driving.
The rest of the time the Mobius works fine. I'm not sure if the problem is:
- my car somehow momentarily cutting power to that circuit, causing the Mobius to power down (note that my radar detector on the same circuit does not lose power at all)
- a faulty 12v-5v adapter where power is interrupted for some reason
- a faulty Mobius
Ideally there would be a simple setting on the Mobius where if it has power, it is on, and if it loses power it is off. Right now it seems like a momentary loss of power causes it to turn off (or not turn on fully), and it doesn't try again.
Appreciate your help.
thanks
- a faulty Mobius
thanks
