markus
- May 18, 2021
- Toronto, Ontario
- Canada
- VIOFO A229 Pro 2ch, VIOFO A119 V3, 70mai Smart Dash Cam 1S
Hello again,
I have a 70mai Smart Dash Cam 1S, and the 70mai hardwire kit. I know the 70mai Smart Dash Cam 1S does not support parking mode, so I'd like to know the best way to hardwire it with the hardwire kit, which has three wires.
The black ground wire is pretty obvious. It's really what to do about the yellow ACC, and red Power wires.
I'm going to guess I'd want to use only a switched ACC fuse with the add-a-fuse, as I do not need / want constant power. The question is, which wire(s) should I connect up? Just the red wire, or should / could I connect red and yellow together, and then insert that into the add-a-fuse?
Thanks in advance for any advice.
