C Chuckk New Member Joined Apr 4, 2015 Messages 3 Reaction score 0 Country United States Apr 4, 2015 #1 My original G90 mount is broken. The rubber suction tears/disconnects from the hard plastic base. Where can I buy a new mount?
Mandami Active Member Joined Aug 20, 2014 Messages 557 Reaction score 217 Country France Dash Cam G90 A7LA70 1, 2, 3, 4 Apr 4, 2015 #2 You can try sending a message to Dome: http://www.szdome.com/service-faq.html http://www.aliexpress.com/store/107697 Could you post some pictures ? maybe it's fixable. I also had some problems with the mount, but in the end I fixed it using some glue, sandpaper and a black marker Let us know how did you solve the problem.
OP OP C Chuckk New Member Joined Apr 4, 2015 Messages 3 Reaction score 0 Country United States Apr 4, 2015 #3 Thanks Tobby. Here are the pictures. Any suggestion on how to fix it?
W Way_Farer New Member Joined Mar 31, 2015 Messages 29 Reaction score 5 Country India Apr 4, 2015 #4 Chuckk said: My original G90 mount is broken. The rubber suction tears/disconnects from the hard plastic base. Where can I buy a new mount? Click to expand... Check this link
Mandami Active Member Joined Aug 20, 2014 Messages 557 Reaction score 217 Country France Dash Cam G90 A7LA70 1, 2, 3, 4 Apr 5, 2015 #5 Chuckk said: Any suggestion on how to fix it? Click to expand... 1. Remove the plastic cover (using a needle or a guitar pick like tool) and then remove the two screws 2. remove the other two screws (which are near USB port) 3. Remove the top part; pay attention to power cables. Remove the pin. 4. now you have access on suction cup and its support. 5. Use a clamp and a good glue to glue them together. Don't use acetone based glue. If you already have a good glue, the cost of repairing is almost zero. Otherwise, you can order a new mount. Next time use this bit when removing the suction cup from the windshield. Last edited: Apr 5, 2015
OP OP C Chuckk New Member Joined Apr 4, 2015 Messages 3 Reaction score 0 Country United States Apr 6, 2015 #6 Thank you very much. I will try to fix it first.
