Hi Folks, newbie to this site..
Have been bought a Mini 801 Dashcam (No internal storage and no GPS) for Christmas from Amazon in which i'm currently using a Scandisk 32GB Class 10 card. The camera is great however once the card reaches full capacity it displays 'Storage IO error' and then turns itself off which is quite fustrating.
I've had a look at the 801 Mini FAQ and notice its a common problem and have tried to update to the 20130924 firmware (which is believed to rectify the issue) however when I transfer it into the root of the card the camera does not recognise it. I've tried changing the extensions as per the FAQ however again its not playing ball..
I've looked at the cameras current firmware via the menu on the built in LCD and it shows the camera being on 20131025 firmware, which is obviously newer than the 20130924 which is meant to fix the 'storage io error'
Has there been any newer firmware released for the camera or it is likely to be the SD card I'm using and if so can you anybody recommend a better one to use?
Cheers
Cheers
