Here is my amateur attempt at a review of the B1M
A foam is a good idea to avoid the wind noise lol...
Foam is not good against wind, foam is used for indoor microphones where there is no wind. You want fluff for a bike cam:
Not a bad review. I will agree if you compare it to the Innovv is so much cheaper and basically your getting the same thing. I have used many cameras over the years but found like you they are not easy to use on the move, this is. I have mounted my remote on the screen support bar which is ideal for me. I have an older BM to yours and am getting TMP problems I need to sort. The battery drain I have only just found out about. Brand new Odyssey battery fitted recently after 10 years and it went flat..... I have red to battery and yellow to feed from DIN port which turns of on the CanBus. How have you done the feed to stop the battery drain, both to CanBus?
