I'm waiting on a A139pro-3ch. I have only an occasional need for the interior camera. Has anyone hot connected the interior camera? I'm thinking the higher rates with 2 cameras and dropping down when I need 3.
The little connectors can be a little delicate
As my esteemed colleagues have cautiously mentioned, since I started using Viofo dash cams in 2020 I've learned to say a silent prayer to the top three deities, and do that four point cross motion across my chest every time I disconnect, and reconnect a rear, or IR camera to the main unit. Sometimes the main camera unit will act "wonky" for a few power cycles until it settles in, and starts working reliably agian.They cable connectors can be a bit stubborn at times when being removed and I'm not sure how resilient they are to repetitive insertions/removals.
Sounds like you'll need to experiment.Thanks for all the replies. I get that the connectors are not very robust. I would never disconnect any connector from any device by pulling on the cable. I don't anticipate plugging directly into the front camera repeatedly as it would be too awkward and I expect too fragile. I'll know more after seeing the connector. Even though this is not going to be a regular thing I would make, at a minimum, extensions to serve like a port protectors.
It should be mentioned that many devices support hot swapping by design. I thought maybe someone here knew. I'm just trying to get a jump on my configuration options.
It all depends on a few factors which way I try to go.
It would have been nice if this was selectable by a front push button or soft setting, but I understand why not. Maybe I'm the only one who ever considered having 2ch/3ch user selectable. Having a wi-fi switch is already an unexpected bonus.
- The perceived front performance lost between 2 and 3 cameras with my eyes, everyone is different.
- How the system reacts. ie. does the front camera revert back to higher performance settings or must the settings be changed manually. What happens to higher performance settings if a 3rd camera is attached. etc.
- The power consumed, both total and the relative difference between 2ch and 3ch. I don't see much need to monitor the interior when parked.
- The boot up time and decay time on power disconnect, if I do need to cycle the power while switching.
- How much signal degradation occurs on the interior camera if I insert switching components.
- If I have to sequence power down, connect the camera, power up, the reverse and the required delays. Certainly more complex hardware and automation than just engaging the camera signal alone.
I wonder if disabling the interior camera via this method opens up the higher bitrate & frame rate option for the front camera, as if the interior camera was unplugged / didn't exist.The A139 has an option to enable/disable the interior camera with a long press of the emergency lock button. I believe the A139 Pro has the same option.
I've never had a Dash Cam before, so I'm a little leery of having cameras pointing at my face, recording me pick my nose & singing
