I wish I had more time to dig into this but I haven't even played with parking mode yet with my 3 wire kit. I'd like to get familiar with my new cam before I start messing with it.
I don't have the app installed on my phone to do a Wireshark capture, but below are some pertinent lines from the decompiled app's code. I copied from several diferent files and methods so this is not all one code segment and I might have overlooked some. I also don't know what version of the APK I decompiled. I just grabbed the first one I found on a third party app repository. This is an easy reverse engineering project to learn how to do it. It'd be fun to explore if I had the time but I don't.
Maybe someone else can take it from here.
private static final String SCREEN_SUFFIX = "?custom=1&cmd=4002";
private static final String THUMB_SUFFIX = "?custom=1&cmd=4001";
private static final String ADD_PARAM = "&par=";
private static final String ADD_STR = "&str=";
private static final String BASE_COMMAND_URL = "
http://192.168.1.254/?custom=1&cmd=";
public class Command_A129 {
public static final String A129_FIRMWARE_FILE_NAME = "FWA129.bin";
public static final int BEEP = 9403;
public static final String FIRMWARE_A129 = "A129";
public static final int IMAGE_ROTATE = 9413;
public static final int RESTART_CAMERA = 9423;
public class Command {
public static final int AUTO_POWER_OFF = 3007;
public static final String BASE_URL = "
http://192.168.1.254";
public static int BEEP = 9094;
public static final int BOOT_DELAY = 9424;
public static final int CAMERA_MODEL_STAMP = 9216;
public static final int CAPTURE_SIZE = 1002;
public static final int CARD_FREE_SPACE = 3017;
public static int CAR_NUMBER = 9422;
public static final int CHANGE_MODE = 3001;
public static final int CUSTOM_TEXT_STAMP = 9417;
public static final String DEFAULT_IP = "192.168.1.254";
public static final int DEFAULT_PORT = 3333;
public static final int DELETE_ALL_FILE = 4004;
public static final int DELETE_ONE_FILE = 4003;
public static final int FIRMWARE_VERSION = 3012;
public static final int FORMAT_MEMORY = 3010;
public static final int FREQUENCY = 9406;
public static final int FS_UNKNOW_FORMAT = 3025;
public static final int GET_BATTERY_LEVEL = 3019;
public static final int GET_CARD_STATUS = 3024;
public static final int GET_CAR_NO = 9426;
public static final int GET_CURRENT_STATE = 3014;
public static final int GET_CUSTOM_STAMP = 9427;
public static final int GET_FILE_LIST = 3015;
public static final int GET_UPDATE_FW_PATH = 3026;
public static final int GET_WIFI_SSID_PASSWORD = 3029;
public static final int GPS = 9410;
public static final int GPS_INFO_STAMP = 9214;
public static final int HEART_BEAT = 3016;
public static int IMAGE_ROTATE = 9093;
public static final int LANGUAGE = 3008;
public static final int LIVE_VIEW_BITRATE = 2014;
public static final int LIVE_VIEW_URL = 2019;
public static final int MOTION_DET = 2006;
public static final int MOVIE_AUDIO = 2007;
public static final int MOVIE_AUTO_RECORDING = 2012;
public static final int MOVIE_BITRATE = 9212;
public static final int MOVIE_CYCLIC_REC = 2003;
public static final int MOVIE_DATE_PRINT = 2008;
public static final int MOVIE_EV = 2005;
public static final int MOVIE_EV_REAR = 9217;
public static final int MOVIE_GSENSOR_SENS = 2011;
public static final int MOVIE_LIVE_VIEW_CONTROL = 2015;
public static final int MOVIE_MAX_RECORD_TIME = 2009;
public static final int MOVIE_RECORD = 2001;
public static final int MOVIE_RECORDING_TIME = 2016;
public static final int MOVIE_REC_BITRATE = 2013;
public static final int MOVIE_REC_SIZE = 2002;
public static final int MOVIE_WDR = 2004;
public static int PARKING_MODE = 9421;
public static final int PHOTO_AVAIL_NUM = 1003;
public static final int PHOTO_CAPTURE = 1001;
public static final int PIP_STYLE = 3028;
public static final int POWER_ON_OFF_SOUND = 8200;
public static final int REAR_CAMERA_MIRROR = 9219;
public static final int RECONNECT_WIFI = 3018;
public static final int REMOTE_CONTROL_FUNCTION = 2020;
public static final int REMOVE_LAST_USER = 3023;
public static final int RESET_SETTING = 3011;
public static int RESTART_CAMERA = 9095;
public static final int SCREEN = 4002;
public static final int SCREEN_SAVER = 9405;
public static final int SET_DATE = 3005;
public static final int SET_NETWORK_MODE = 3033;
public static final int SET_TIME = 3006;
public static final int SPEED_UNIT = 9412;
public static final String STREAM_MJPEG = "
http://192.168.1.254:8192";
public static final String STREAM_VIDEO = "rtsp://192.168.1.254/xxx.mov";
public static final int THUMB = 4001;
public static final int TIME_LAPSE_RECORDING = 9201;
public static final int TIME_ZONE = 9411;
public static final int TV_FORMAT = 3009;
public static final int WIFI_NAME = 3003;
public static final int WIFI_PWD = 3004;
