dashingthrusnow said:What's the best way to aim your dash cam? In other words, what should we be capturing? Here's a snapshot of mine... A little bit of the dash and the rest outside. ITB-100HD SP with 12 Mbps mod. Lots of glare off the windshield!
dashingthrusnow said:Thanks Niko!
I guess on my Prius, the hood is so slanted down, that it's impossible to see a 1/4 of the hood!
Hillbilly said:dashingthrusnow said:Thanks Niko!
Of course if you have a sloped bonnet that wont work but the same angle would apply A Blackvue has a logo on one end and the instructions say to have it 10deg below horizontal at the front
Like this with a DR500WIfi
or even this with a RD400G
This in a Chrysler 300 in Arizona with the DR400G
Thanks Niko. It helps. A picture is always better than a thousand words.niko said:alau0115 said:Niko, mind if you could elaborate in words or a diagram for a noob like me? I would like to learn. Thanks again.
This would explain my words.
mariomart said:With the Honda Odyssey I drive it is not possible to see the bonnet. I don't like to waste my image on my dashboard so I adjust mine so the dash is just in frame. This is with a GS900 (VF960S).
ufonauta said:Welcome
Sorry for my bad English but I use google translator.
So I got my camera has a GS 5000 and I've tried all sorts of positions, but I can not eliminate windshield glare.
If you have some tips for you, I'd appreciate it.
mariomart said:I re-aimed my GS900 as per suggestions.
Here is my OLD setup.
Here is my NEW setup.
What do you think?
Cheers Mario
niko said:Your old set up was 50 / 50, new one is about 25 above horizon / 75 below, - it's much better than old set up. Of course you probably will not catch that much a meteorite , but most important is to have much clear readings on the road ( white balance and exposure value ) which is much better if use proportion rule: more to the road and darker places, - less to the sky.
