Open the housing, then loosen the hex nut securing the lens using the included Allen key and rotate the lens till you get the desired focus.
Thanks for the reply.
There was no key with the Maxi but have one from the mobius 1. However I cannot find the nut on the lens "A". Where is it?
Due to sewer works in the back yard where my car are normally parked i can not park there and so are now in front of the building where i have gotten my car vandalized 2 times.
BUT ! this time i have a "wider" 1080p CCTV camera on the street, and i have just put up my maxi with the 12 mm lens to give me a identifying chance if anyone should stop beside my car and do something to it.
The repair of the sewer should be done Tuesday afternoon, so just 2 nights i have to make do with this makeshift setup.
SRY i wanted to start with i never really bothered with peeling any glue off lenses, i just unscrew them, and then peel a little of if i need to screw it in further than it was.
And then go of topic,,,, yet again.
Is there a reason why this lens was glued whereas the earlier versions were held via a screw.I don't know about the merits of not peeling the old glue off but for me the issue with unscrewing certain lenses is getting a recalcitrant lens to twist off in the first place, hence the heat gun. One of the Maxi lens modules sent to me (a prototype) was glued on so strongly it was virtually impossible to remove.
I am beginning to dislike this camera more and more especially with no answer yet to the software problems.![]()
I would have thought having to break the glue and then re-glue would have the same result.the screw makes sense but I can see their point if it caused excessive returns which were just user error
I would have thought having to break the glue and then re-glue would have the same result.![]()
In addition to the response from @Dashmellow , I can see three practical reasons for not having a set screw on the A lens:Is there a reason why this lens was glued whereas the earlier versions were held via a screw.
