Kot-Begemot
- Oct 9, 2016
- Ukraine
How to upgrade firmware! ?? Now I is 20160705, and I want to upgrade to 20160825, have tried different methods, and it did not work, please help
If you are using Linux or Mac, make sure firmware.bin is renamed to all caps: FIRMWAREBIN.
what methods have you tried?
Make sure you have file extensions turned on and don't have a file named firmware.bin.bin
As I said make you do not have a double file extension
I know you already tried (almost) the same method, but please try again, step-by-step, it have to work. (WINDOWS)
0.) if you ever tried to partition your SD card, then revert it to original, or try with a different card
1.) Remove SD card from your device
2.) Put SD card into dedicated card reader (not camera)
3.) Format SD card by Windows (quick format, FAT32 for 32GB or below | exFAT for 64GB or above)
4.) Download the firmware from http://nanodashcam.com and decompress FIRMWARE.BIN
5.) Copy FIRMWARE.bin to your SD (as is, do NOT rename, TotalCommander preferred)
6.) "Safely remove" your USB drive (card reader) [ right click -> eject ]
7.) Put this SD card to your NanoQ 0903
8.) Plug your NanoQ into car charger or phone charger (NOT usb port on your computer)
9.) The red led will blink (with screen off). Once it's done, it will restart itself
10.) Check your FW version in menu and if everyhink ok then format SD card in camera
Sorry for detailed steps, but maybe there are any little thing you missed
I tried to do on your instructions, and failed perepror****, formatted in exFat and Fat32 format with different sizes of the cluster and above, the device understands only the size of 32 clusters, as above, but when you turn on the device, as always flashing red LED that indicates that the start record and the firmware is still 705
what size memory card are you using?
