Infinite boot loop
Nenzyz
Ukraine
Can someone help to find the way to make a recovery flash of firmware or something similar.
Camera is starting chime sound infinitely, not recognized via USB nor card.
firmware in SPI is damaged for some reason?
a firmware update will help? please have a try first.
Hi, was this problem solved for you? Mine has started doing same since last night. First, when connected to the base unit (GPS), it loads and then freezes forever. If I power on just the camera without base (GPS) unit, it does not start and infinitely keeps giving starting chime sound like yours does. I tried to load a new firmware I just realised that it was released on 24th Jan. But it would not boot at all and stuck on starting slash screen with infinite stating chime sound. I have not tried to load the firmware with the base unit (GPS) attached. I will try that tonight. But, I would like to know if you have managed to fixed this issue or not?
Few days back, the camera was automatically shutting itself down after few minutes. If I unplug and plug back in, it starts for some time and then shuts it down. The problem went away next morning without doing anything.
@jokiin or @Rayman.Chan if you guys can help with this as well please.
Thanks,
Mihir
Hi, I got a new firmware from the seller, flashed and amazingly it starts working.
For me there was no difference with base or without. Chime sound all the time with initial boot screen infinitely.
Thanks for your quick reply. How did you flash it? With the base unit (GPS) attached or without? I tried without and it does not do anything but stuck on startup splash screen.
Here is the original procedure
Format of card with camera was impossible for sure.
I flashed without base as it is stationary in the car.
Code:
Steps for upgrade:
1) Download .rar ------> decompression
2) Copy firmware.bin to an empty memory card
3) Insert the memory card into your DVR, turn on DVR, it upgrades automatically
4) Move out the memory card after finish upgrade
5) Default the camera (setting)
Note:
1) Make sure the camera is full charge.
2) Make sure the memory card is empty
3) Please format the memory card on camera (Important)
We recommend you use Samsung Pro micro SD card.
Any other questions please feel free to contact us.
Regards
Connie
Copy firmware.bin to an empty memory card 3) Insert the m
Code:
Steps for upgrade:
Note:
Regards
Connie
Again thanks for your quick reply.
I am trying to flash it without base using powerbank. I will try it in car tonight.
Code:
Steps for upgrade:
Note:
Regards
Connie
Finally managed to get it back to life. The reason it wasn't flashing was that I formatted sd card with exFat format as there was no option for FAT32 on win10. I downloaded third party tool to format it to FAT32 and it was able to load the new firmware. Let's see for how long it lasts.
Thanks for your help @Nenzyz
