cyberspace
- Jun 27, 2018
- Australia
I’ve seen some discussions but no solid answer?
Yes, it has real 60fps, although for normal dashcam use I recommend using it at 30fps, other people prefer the 60fps.I’ve seen some discussions but no solid answer?
Not true, at least not in A129+. 60 fps are always maintained with the price of darkening the image (when in full darkness, only with headlights). But I only tested a beta firmware (1.4TST, last for A129+), so who knows what will be in the stable version.It may drop to 30fps in dark darkness, not sure.
If you have your headlights on then I wouldn't expect it to need to use 30fps, or even 1/60th second exposure, it is probably several times faster with the Starvis sensor it is using!Not true, at least not in A129+. 60 fps are always maintained with the price of darkening the image (when in full darkness, only with headlights). But I only tested a beta firmware (1.4TST, last for A129+), so who knows what will be in the stable version.
I even tested it w/o headlights and the framerate remains 60.If you have your headlights on then I wouldn't expect it to need to use 30fps, or even 1/60th second exposure, it is probably several times faster with the Starvis sensor it is using!
I like to use it until darkness fall. But even in the night, with headlights, it is acceptable.I've been using 60fps for many months now, since firmware 2 came out, day and night, and mine's fine in both. No complaints here.
