Just bought a B4K! The link to download the B4K GPS Player for Windows doesnt work
DV688 Video Player
blueskysea-inc.com
May I know this dashcam firmware version?The link to download the B4K GPS Player for Windows doesnt work
The firmware version is v009, the latest version from your website.May I know this dashcam firmware version?
>Is there a way to use a suction cup mount instead of the permanent sticky tape?
An optional suction cup holder is available for B4K dashcam, but it has no built-in GPS module from the suction cup holder!
I tried to download that but it just saves as an HTML file. What file type is .7z?You can download it hereGPSPlayerx64.7z
drive.google.com
I have Winzip and WinRar. I will download 7Zip tomorrow. Thank you!download 7ZIP to extract the file
windows can handle zip files but doesn't do 7z filesIMO the file should be in a state where you could unzip it with what is in windows, or maybe also as a raw installer to DL.
Anyway, it works with the third-party GPS Player: DVplayer.net and dashcamviewer.comI have Winzip and WinRar. I will download 7Zip tomorrow. Thank you!
Thanks for the tip @kamkar! After removing the adhesive pad 3 times to find the best mounting spot, I will never ever purchase another non-suction mount Dashcam. I ordered a mount meant for radars like the one you posted and used painters tape to attach the GPS module to the mount and used the suction cup to mount my B4 with and took it for a test ride. Due to the tape not being tight enough, bumps caused slight vibrations in the mount and video. I then used a '3M VHB' pad and cutting to size, attached the GPS to the module. Another road trip and no problems. Thanks again for the tip.....Attachments of pictures as finished:There are a few universal suction cup mounts some have used for dashcams too, i think originally meant for radar detectors.
Something along these lines, so you still stick the camera in place but to the universal mount and not the windscreen.
https://www.buyradardetectors.com/arkon-bt010.html
It could also so some other mount work, @estore009 would probably know if thats the case.
Just measured that @estore009, and its 2 3/8 inches. All of my other suction cups are 2 1/8 inches. But it does look much bigger but 2 3/8 inches is what it is(diagonal). I have had several smaller ones lose suction and dump my cams to the floor board when facing the sun on very hot days, so this slightly larger one might hold...time will tell. The ones that fell were all on my trucks front wind shield.Looks like the suction cup holder size is huge?
