Tommy
- Mar 28, 2013
- Romania
- iTronics ITB-100HD x2
Hey there,
First of all, I am not a very technical person when it comes to software (I not a programmer nor anything related).
I've been trying for months to pay someone to increase the bitrate of my dashcams. I am sure it can be done.
Now, 1) the manufacturer (iTronics) blew me off in a second 2) I haven't managed to get get a reply from the russian guys that made the BlackVue or FineVu modifications 3) here on the forum, someone wasn't going to test on their own cam.
So I had to take this into my own hands.
Step 1
From the Russian forum, and these two other links ( http://f.redflagdeals.com/showthread.ph ... type=basic + viewtopic.php?f=6&t=6&start=50) it seems that after decompressing the firmware for the BlackVue cameras, the settings need to be modified in the av_server.sh file.
Problem is, after decompressing the iTronics latest firmware (2.1) : http://ipassmall.co.kr/ipassblack/down_ ... 3%29%2Ezip, I don't have that av_server.sh file. I have pretty much a very similar structure (since both cameras use Linux and bot cameras need a similar software structure for the DR368 or similar Texas Instruments processor).
I used http://sourceforge.net/projects/hexplorer/ to search for the config parameters needed to change the bitrate. Something like :
av_server.out DM368 %sAEWB TI2A %s %s %d VBR AUTO %d MENUOFF &
After decompressing the firmware.bin I get two files:
itb100_fw.bin and itb100_kernel.bin
After further decompressing itb100_fw.bin (because itb100_kernel.bin has nothing relevant to setting the bitrate, after searching with a full text HEX tool), I further get a folder called IPNC, and inside of it:
As you can see, there is no av_server.sh file, like BlackVue has. After searching file by file with: http://www.sowsoft.com/search.htm, for "av_server.out", the only two files containing that string are the av_server.out itself and a test file (which is probably used for testing, not for actual parameters).
The content of the modified av_server.sh file from the modified BlackVue firmware is:
I have also extensively searched Google for related information, like:
https://www.google.com/search?q=av_serv ... _HAQQhsr6w
If someone can help further, I would appreciate it.
Step 1
![EunxcTI.jpg](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FEunxcTI.jpg&hash=6f15374a227d845085c5a8e2a9a637f3)
#!/bin/sh
SIZE=1080P
#SIZE=5MP
# other possible resolution options:
#2MP
#3MP
#5MP - does not work - not enough memory
#720P_MAX
BITRATE="15000000"
# Default bitrate is 5000000
exec /mnt/nand/System/wrap/av_server.out DM368 AUDIO 8000 AAC 24000 AEWB TI2A $SIZE H264 $BITRATE 1 VBR AUTO $((BITRATE + 500000)) MENUOFF
