Just a few questions
Oldie70
Having received an Auto-Vox 118C for Xmas, I've recently had it fitted. Obviously, I've been playing around with it in the meantime, as well as going through past posts. So I've ended up with a few questions:
1. When I connect the cam to my laptop, I get a "Low Battery" warning two or three times. Does this mean that the USB socket isn't giving enough power, or is the small battery for the date/time running low?
2. Connected to the laptop, if I select "Camera" it just freezes up, and I have to reset to get out of it. Again, is this just because it's a laptop socket, or is it usual?
3. I can't adjust the settings when it's connected to the laptop. Is this normal?
4. Would any of the above be different if I connected the USB lead to a normal electrical socket via a phone charger?
5. I can view the files in Windows Media Player, though obviously it won't link them. I've downloaded Registrator Viewer, and even found instructions for it. Is there any way to set the source for files (in my case F🙂 rather than having to work down through the directory.
6. Having viewed the files and deleted them, is it necessary to format the card again?
Thanks for any replies.
Usb2.0 power is not sufficant for camera may be usb3.0 is better. A118c has no battery only capacitor inside.
A118c has no battery. Also use your laptop from power source not battery. When using battery laptop will reduce the current of the usb for power saving.
Thanks for the replies. I've been a bit busy, hence my delay in posting.
So the A118C doesn't have a battery, even to maintain date and time? Do I assume the "low battery" warning is because they use standard software across the models, rather than a genuine fault?
I hadn't thought of the difference between using a laptop on battery, and plugged in. I'll try that, as well as the phone charger, later today.
it has a small button cell on the mainboard which holds time and date
low battery sounds a bit generic but it's an indication of the power source being too low to correctly power the camera
Well, that was interesting. Plugged into the laptop, it made no difference whether the power lead was in or not. However, plugging it into a phone charger gave a completely different outcome.
The cam went straight into 'camera' mode, without any 'mass storage' option or 'low battery warning. Which meant that I could go through the menus in comfort, with good visibility. I formatted the card, and then took a couple of short videos. Looking at these on the laptop, I found that both of these were in the RO folder, not the Movies one.
When I opened them in Registrator Viewer, they were shown as 'locked' files.
Is this significant?
I would suspect you jostled the camera enough to activate the g sensor while shooting those short videos, that would have locked them as it should.
and on that note, i suggest you turn the G-sensor completely off. it tends to be oversensitive in this camera, and before you know it, the RO folder will be full of clips and the card will be full, and the cam will stop recording. unfortunately it doesn't beep or anything to let you know the card is full. it just shows a message on screen briefly, then turns itself off. not very useful!
CDNinHH : I turned the camera through 180 degrees to see how well it filmed indoors, and then back again. Which was probably seen by the sensor as pretty huge huge movements.
Gibson99 : I've come across mentions of that before, when reading through the threads. Next time I have the cam indoors, I'll turn the sensor off.
Incidentally, when taking the unit out of the car, is it better to remove the power lead first, then slide the cam out, or vice versa? Although the power cable is pushed up into the lining, there's nothing fastening it, and it drops out every time I pull on the cable.
slide it up off the bracket first, you'll end up breaking the connector if trying to get the power lead in or out while the camera is mounted
